135 MF power steering
Rob Blankenship
05-16-2005 20:49:04
The power steering recently quit working on my 135 MF. A local mechanic found a couple of teeth missing on the steering sector. After replacing the steering sector, stopping the leaks, bleeding the whole system, and checking the pressure everything seems normal. However the power steering still isn't working. What might we have overlooked?
DavidP, South Wales
05-17-2005 11:20:07
 Re: 135 MF power steering in reply to Rob Blankenship, 05-16-2005 20:49:04
Hi,
Do you have correct up and down movement in the top collar in the steering column? Is there any loss of movement in the barrel linkage adjuster for the spool valve? Is operation OK manually?
Cheers
DavidP
