power steering leak
rerun
05-14-2005 15:07:15
help! just bought my mf 202 year unknow may be 1960 . fluid is coming out of steering shaft what do i need to do or replace.
Big Dean
05-14-2005 16:31:20
 Re: power steering leak in reply to rerun, 05-14-2005 15:07:15
That leak is caused by the seal in the bottom of the steering column. The steering wheel and dash has to be removed. You have to disconnect the line from the oil pressure gauge and any wires that are to short to let the dash raise up over the steering shaft so you can lay it up on the fuel tank out of the way. Be sure to mark any wires you disconnect so you get them back in the right place. Remove the three bolts that holds the steering column down and lift it up off of the steering shaft and replace the seal in the bottom of it. Be sure to hold down on the steering selector valve under the column so the 0-ring under it does not fall out of the groove it fits in. If I can be of further help Email me.
