re:3090 hyd pressure
lm
05-13-2005 14:59:47
hi had a post on this forum last week about MF3090 low hydraulic pressure light coming on and then pto disengaging toolbox said it may be dodgy pressure switch where on tractor will i find the switch how can i check to see if this is the problem, is there any other things i should check? steering is fairly heavy at low engine speed too ( conpared to a 590)
the rev counter on the dash doesnt work also tractor is registered in early 1987 any help is appreciated thanks
Toolbox
05-14-2005 00:10:46
 Re: re:3090 hyd pressure in reply to lm, 05-13-2005 14:59:47
The 17bar pressure switch is located on the hydraulic pump cover at the top right hand corner, just to the rear of the row of solenoids. The pump cover is behind the rear right hand wheel.
You can eliminate the switch by joining the wires up temporarily if this cures it, the switch is dodgy or you have a low oil pressure in the low pressure circuit, if you cant test the pressure and you suspect the switch the only way is to change the switch and try again.
Its worth changing your hydraulic filter to try to over come you heavy steering and check the tick over is not to low it should be 950rpm.
lm
05-15-2005 15:44:01
 Re: re:3090 hyd pressure in reply to Toolbox, 05-14-2005 00:10:46
thanks toolbox , will check it out tomorrow
