MF 3080 4WD not engaging
TOS
05-13-2005 06:27:54
Hi!
I got a MF3085(90)and the 4wd will not engage. The light turns on. I've checked the solenoid (switched it with the diff, cut the power to the solenoid, checked the split pins on the hubs. Ok.)
I've jacked up the front of the tractor with the engine off, and the wheels run free. Should be engaged??
Thankful for support!
Tor, Norway
pquinn
05-13-2005 13:26:05
 Re: MF 3080 4WD not engaging in reply to TOS, 05-13-2005 06:27:54
Hi
I would check the coupler on the drive shaft as this can wear from not greasing the front axle. When you jack up the front wheel it should not turn as the 4wd engages once the engine is stopped.
