A3.152 oil straner assembly.... NEED HELP PLEASE!
William Bos
05-12-2005 14:27:20
Hi,
I went to my MF dealer today, and we loked up ther part number for an early 135 D 3.152, and it did show different part numbers, and the one we need is DISCONTINUED!! Please, help!!
Thanks,
Will
DavidP, South Wales
05-13-2005 12:08:30
 Re: A3.152 oil straner assembly.... NEED HELP PLE in reply to William Bos, 05-12-2005 14:27:20
Hi William,
Yes, the older type is discontinued. It is not difficult to fit the later one. The strainer in the sump plate will have to be cut off. Make certain that you have all of the parts for the new pipes etc. There are quite a few. The oil pumps are the same so no problem in the mounting.
When you have it all assembled, fit the sump in place without a gasket and make sure that the strainer disc also without a gasket will fit without having to tighten it down. If all is OK the sump and plate can then be fitted with gaskets safe in the knowledge that there are no stresses on the pipes or strainer. Oil level will remain the same.
Cheers
DavidP
William Bos
05-13-2005 15:28:46
 Re: A3.152 oil straner assembly.... NEED HELP PLE in reply to DavidP, South Wales, 05-13-2005 12:08:30
Hey David,
Is this the later 135 type that just " sits " in the bottom of the pan?
Do you have more info you would like to share?
Thanks alot
Will
DavidP,South Wales
05-14-2005 11:09:13
 Re: A3.152 oil straner assembly.... NEED HELP PLE in reply to William Bos, 05-13-2005 15:28:46
Hi Will,
Yes it does sit on the floor of the pan (sump) don't think there is a lot more I can tell you but if you have any specific questions I'll do my best to answer them.
Cheers
David P
