A3.152 oil straner assembly....
William Bos
05-10-2005 15:24:39
Hi,
We are in need of a A3.152 oil strainer assembly, and tubes of available. It is the old style, that is bolted on the bottom of the pan..
Thanks in advance
Will
DavidP, South Wales
05-12-2005 13:54:25
 Re: A3.152 oil straner assembly.... in reply to William Bos, 05-10-2005 15:24:39
Hi Big Dean,
We have quite a few break at the point where the stay bracket is brazed to the pipe, never resulted in engine failure only low oil pressure. Every 35 and 135 that we have overhauled has had the new type fitted with the rubber grommet etc as a safety precaution. Cheaper than another rebuild.
Regards
DavidP
Big Dean
05-10-2005 23:24:57
Will if Gary is not able to help you send me a email I have a couple of places that I am sure will have it In all the years I worked on those engine I never saw one of them broke Big Dean
Yeoman
05-11-2005 12:14:58
 Re: A3.152 oil straner assembly.... in reply to Big Dean, 05-10-2005 23:24:57
Glad to see your post big guy. Many of us here appreciate your wisdom and experience. Hope to hear (see) from you for a long time to come. best, Phil
GaryF
05-10-2005 15:45:11
You should order from MF. There was a modification made to the original design which was prone to cracking at a weld due to engine vibration the pickup tube broke off above the engine oil level. We all know what happens to engines that don't get oil!!! I think the same strainer, grommet, tube(s) and olives could be used on the A3-152
William Bos
05-10-2005 18:44:28
 Re: A3.152 oil straner assembly.... in reply to GaryF, 05-10-2005 15:45:11
Hi,
I just came from my MF dealer today. That part was discontinued.
What do I do know??
Thanks
WIll
GaryF
05-10-2005 19:05:03
 Re: A3.152 oil straner assembly.... in reply to William Bos, 05-10-2005 18:44:28
A friend of mine just rebuilt one of these engines in the last month. He used the parts mentioned. Let me find out for you. I will repost. It may be that the parts for the AD.152 interchange with the A.152and the parts guy at the dealer didn't pick up on it.
Gary
GaryF
05-11-2005 08:13:56
 Re: A3.152 oil straner assembly.... in reply to GaryF, 05-10-2005 19:05:03
Strainer and tube assembly same as AD3.152. MF nolonger sells the original tube with the welded bracket. Replacement part is a tube with a rubberlinned bracket and clip that bolts under
Gary
William Bos
05-11-2005 12:42:39
 Re: A3.152 oil straner assembly.... in reply to GaryF, 05-11-2005 08:13:56
Hi,
So, does this mean that one from a MF 135 will work? And do the bolt in the bottom of the pan?
Thanks,
Sorry for all the questions.
Will
GaryF
05-11-2005 13:58:53
 Re: A3.152 oil straner assembly.... in reply to William Bos, 05-11-2005 12:42:39
Yes, if they want a serial # explain what you need and choose an early production date (1966)My parts book (1974) shows 3 different pickups there may only be 1 now.
Gary
William Bos
05-11-2005 14:10:16
 Re: A3.152 oil straner assembly.... in reply to GaryF, 05-11-2005 13:58:53
Hi,
Ok, thanks alot. I hope they have the one I need! I will keep you guys posted!!
Thank you everyone who posted!!
Will
