Massey-harris paint
drust
04-25-2000 05:24:55
ready to paint a massey harris 22 and what are the pro/con of using massey ferguson red from dealer vs getting it from napa ?
Raymond Courchesne
07-26-2006 13:15:26
 Re: massey-harris paint in reply to drust, 04-25-2000 05:24:55
For your choice of color paint go to the NAPA store or any automotive dealer with a paint specialty and asked for the codes supplied by one
of our friend. If you want to make a very nice job
you will have to sand blast the whole tractor,then
apply an epoxy primer. Please make sure that your
tin is dent free and then apply a base coat/clear
coat type of paint. The reason is that enamel paint fades more and also is less uv resistant.
If you want to keep shine on enamel paint you will
use elbow grease to wax the baby a couple times
a year.
Alberta Mike
04-25-2000 12:47:09
Well, the two colors are not the same as far as I know. Massey Ferguson Red is somewhat 'redder' than the Massey-Harris Red (which I would say has more 'orange' in it's mixture). Why not stay with the M-H color if you've got a model 22?
DRUST
04-26-2000 05:58:33
 Re: Re: massey-harris paint in reply to Alberta Mike, 04-25-2000 12:47:09
ALBERTA MIKE, CAN YOU TELL ME THE PAINT CODE ETC FOR THE MASSEY HARRIS. I TALKED TO MASSEY FERGUSON DEALER IN MY AREA AND HE HAS NOTHING ON PAINT FOR MASSEY HARRIS ---SO, CAN YOU SUPPLY ME WITH INFO ON HOW TO GET THE PAINT I NEED. I WANT TO STAY ORIGINAL IF I CAN----WHILE AT IT, WHAT ABOUT THE YELLOW FOR THE WHEELS?
Alberta Mike
04-26-2000 06:34:29
 Re: Re: Re: massey-harris paint in reply to DRUST, 04-26-2000 05:58:33
Here's some color numbers that might help you:
1. Martin Senour Points - Synthol Enamel (NAPA) - MH RED 90G-3743 - MH YELLOW 90T-3744
2. Sherwin Williams Paint -MH RED JK 4036-R -MH YELLOW JK 4649
3. Ditzler Paint - MH RED DQE70364 - MH YELLOW DQE 80533
4. Dupont Imron Paint -MH Red 674UM
I was told that Tremclad Yellow (machinery enamel available up here in Canada) is almost an exact match for Massey Harris yellow, however it is not of automotive quality. I've used a couple of different machinery enamels for the reds, specifically Glidden Safety Red (but that might also be Canadian). It is not an automotive type (Hardener, etc.) paint.
