massey ferguson mowing machine
Gary Cole
05-08-2005 17:00:52
can anyone tell me how to sharpen the blade on the mower? Thanks
DavidP, South Wales
05-09-2005 14:40:29
 Re: massey ferguson mowing machine in reply to Gary Cole, 05-08-2005 17:00:52
Hi Gary,
I'm assuming that it's a cutterbar mower that you are referring to, think you call them a sicklebar?
The correct way to sharpen the blade is first to remove it. You can use a small angle grinder but the edge will not last long. The blade can be mounted in a vice with the points away from you. You will require a 'reaper' file. This is a very fine flat file. Carefully file the blade sections at the angle of the edge until you have an even new edge. ONLY USE THE FILE AWAY FROM YOU. DO not file on the return stroke as this will take the edge off. Before you start it is wise to hold the blade in one hand and just tap the end on a hard floor. You will hear if there are any loose sections that need tightening or replacing.
Cheers
DavidP
