Massey 65 2-spool valve
Jim in Oregon
05-06-2005 08:25:11
I have a MF 65 with a 2-spool valve lever in front of the seat. On the back side toward the rear end of the block there are 2 thumb screw valves, the one on the right is out all the way tha one on the left is turned all the way in. I am installing a loader, I'm wondering if the one on the left needs to be opened up or turned out all the way.
Thanks,
Jim
Big Dean
05-06-2005 18:04:19
 Re: Massey 65 2-spool valve in reply to Jim in Oregon, 05-06-2005 08:25:11
Jim those screws are for setting the valve for single or double acting cylinder. If you are planing on use the left lever to operate one function of the loader you will have fix the three point arms where they can't move or wait for them to raise to operate that part of the loader that they operate.
Jim in Oregon
05-07-2005 08:19:45
 Re: Massey 65 2-spool valve in reply to Big Dean, 05-06-2005 18:04:19
Thanks Dean. Which way should the thumb screws be set for running a loader with a bucket tip on it?
Jim
Big Dean
05-07-2005 10:24:51
 Re: Massey 65 2-spool valve in reply to Jim in Oregon, 05-07-2005 08:19:45
Jim it has been to long I have been retired for over ten years but the best I remember the screw is screwed out for a double acting cylinder.
