Fuel guage on massey 390T
Jarrett
05-05-2005 17:44:39
hello,
my fuel guage was working perfectly, then all of the sudden it went to full and stayed there, when the key is off, it goes to empty, but once key is turned it stays on full, where do i start with this thing?
Jarrettf
05-06-2005 08:31:01
 Re: Fuel guage on massey 390T in reply to Jarrett, 05-05-2005 17:44:39
ive looked behind the guage, all is connected, should i check the float? where do i find the sender?
txgrn
05-07-2005 05:52:02
 Re: Fuel guage on massey 390T in reply to Jarrettf, 05-06-2005 08:31:01
Open ckt; either ground, or your sender wire broke. Sender wire is probably your problem. Sender should be on top of the tank, but JD puts it in the side of the tank on some of their tractors.
Gauge has to match sender so your best bet is expensive, but best, get and OEM replacement. Been there done that and they aren't all that bad for as long as they last.
Automotive don't hold up to the pounding you get working the field. May be for utility, running chores around the place, but not for field work.
Mark
