1130 sticky clutch pedal
mitchbob
05-05-2005 06:08:14
I have been using a 1968, 1130 Massey on a tmr mixer and it has been working great.Now the clutch pedal has started sticking down. It is strange because sometimes it bounces back just fine and other times you have to use your heel to drag it back up. Is the cluch hyd. assist or just a basic manualy operated setup? Thanks, Butch
chuckinnc
05-05-2005 19:28:03
 Re: 1130 sticky clutch pedal in reply to mitchbob, 05-05-2005 06:08:14
that happened to my 1135, i knew i kept the greese fitting to the throw out bearing pumped full. When i removed the plate on the bottom to look at the clutch i found the greese fitting went to a hose that went to the bearing, the hose had rotted and a pound of greese was laying on top of the plate instead. I sprayed oil on the bearing to get it working again.
