Pony Oil Pump Problems
T
05-03-2005 15:21:40
Hello I have a Massey Harris Pony and currently have no oil Pressure. I checked the Relief valve and it looks OK. Could some tell me if the oil Pump is located in the Oil pan or Under the Front Cover. Are there any special things to look out for?????
jjcomp77
05-05-2005 06:26:02
 Re: Pony Oil Pump Problems in reply to T, 05-03-2005 15:21:40
If it has been running check and see if the gauge is bad pull the line of and see if oil comes out when started.
John
T
05-05-2005 16:37:24
 Re: Pony Oil Pump Problems in reply to jjcomp77, 05-05-2005 06:26:02
Hello John The tractor is running, I changed out the gauge with a new one, and pulled the line off, No Oil came out. The tractor seems to run fine and does not Knock. I guess I should pull the bearing caps off and have a Look before I take the engine off. What do you think????
parts man
05-03-2005 15:50:52
The oil pump is on the back of the block in the clutch housing. Check for wear on the gear housing, but more likely is worn crank bearings.
