TE20 (did it myself)
j. cooper
05-03-2005 07:35:32
I have a 1948 TE 20 that wont start. I have fire to points and from coil but not thru distributor cap to plugs. New cap, points, condenser,rotor,wires and coil. HELP...
txgrn
05-06-2005 05:18:42
 Re: TE20 (did it myself) in reply to j. cooper, 05-03-2005 07:35:32
Well you have:
a wire to the center terminal
a cap
a rotor
Plus you have the top of the rotor to connect to the terminal on the under side of the cap.
The new wire is open. Use an old The cap is internally defective. Use the old
The rotor is defective???? You tried the old
But did you insure that the spring tab on top of the rotor is touching the inside button in the under side, center of the cap?
Or is the dist shaft turning the rotor?
Or is the dist shaft turning at all?
Mark
j. cooper
05-06-2005 06:04:09
 Re: TE20 (did it myself) in reply to txgrn, 05-06-2005 05:18:42
I stretched spring in dist. cap so as to touch rotor still nothing.how can I check rotor for right application?Thanks for your input I need all the help i can get .....
Jeff=oh
05-03-2005 10:37:32
You said you have a new dist. cap, points... etc. Did you use the correct type? The TE and TO electrical parts are not intercangeable.
Just a thought.- Post this question on the H. Ferguson board. John from the UK is a wiz-bang on the TE.
BTW I also have a '48 TE. SN #429__ in Ohio.
Jeff
j. cooper
05-03-2005 12:19:40
 Re: TE20 (did it myself) in reply to Jeff=oh, 05-03-2005 10:37:32
I ordered lucus dist. cap with screw in wires and installed . the only difference was rotor,but I tried my old one and still no fire. thanks for the concern....
peltsi
05-03-2005 07:56:11
your problem could be with resistive plug wires, with this machine you should use copper spark plug wires.
kjm
05-03-2005 18:41:57
 Re: TE20 (did it myself) in reply to peltsi, 05-03-2005 07:56:11
j.cooper,I had a new roter break off inside of the cap when it hit.I went through 3 before one worked.
