MF 35 Perkins Engine Knock
Pete Z
05-02-2005 19:34:39
I just purchased a MF 35 with a 3 cylinder Perkins. It has an engine knock. Should I be worried about this and how can I fix it?
Pete Zandstra
05-03-2005 19:14:40
 Re: MF 35 Perkins Engine Knock in reply to Pete Z, 05-02-2005 19:34:39
It is a 3 cylinder diesel. The engine knock is fairly consistent with rpm and load. It is louder than I would expect, but I haven"t heard another one run before. Is there ever a need to adjust the injector pump timing?
txgrn
05-04-2005 06:56:54
 Re: MF 35 Perkins Engine Knock in reply to Pete Zandstra, 05-03-2005 19:14:40
My guess, on older high hour tractors, gear wear may retard the timing slightly.
Why you ask?
My perkie is noisier than any other diesel I've heard, but I think it is what perkie's sound like. It is a consistent rymethc sound; present while operating at a fixed speed, but noisier as I said, upon accelerating.
On timing, your engine should accelerate quickly; not like a 327 Chevy hopped up, but a nice snappy response; no hesitation; crisp and clean.
If you fool with it (the timing) you don't want to loose you current position, and only move it ever so slightly in small steps, and DON'T HAVE IT LOOSE WHILE THE ENGINE IS RUNNING. Gotta stop, adj, start, stop, adj, start.....It is not a distributor on a gas engine.
Mark
txgrn
05-03-2005 06:52:16
What kind of knock? They make a pinging noise, or rattling (unlike any other engine I've heard) when accelerating, especially under load. Guess it is has to do with their indirect injection.
Mark
marlowe
05-02-2005 20:22:43
parts man is right. but is this knock above the normal knock of a diesel they knock when they are ok and some knock more then others. if this is your first diesel find some one that runs diesel and have them give you advice. you did not say it is a diesel but if it's a gas better find the knock fast
parts man
05-02-2005 19:50:54
An engine knock is always cause for concern, you better go looking for it, before it finds you! Could be various causes, one of the most common is worn crank bearings.
