MF65
hdlong
04-27-2005 06:27:50
What will I have to do to replace rear wheel bearings and seals for pantatarim drives also may do brake job and need hyd pump rebuild
Big Dean
04-27-2005 14:44:07
 Re: MF65 in reply to hdlong, 04-27-2005 06:27:50
To replace the planetary bearing you first have to remove the tire and wheel from the axle. Remove the bolts from around the planetary to disassemble it there were two different planetaries used on the MF65. I think some of the parts for them are no longer available from MF unless they have been brought back by ACGO if they were it was after I retired. The brakes you have to also remove the tire and wheel. Remove the axle housing and turn it up on the wheel end. Remove the plate with the bearing or according to which side it is off of it may have the bearing cup. The brake disc & actuator are under that plate. The three point pump you have to remove the PTO shaft from the rear remove the liftcover under the seat from the rear center housing. remove the transmission to differential pinion shaft drive shaft the pump will usually lift out through the top of the center housing. on some that have the Multipower the Multipower pump will not let the pump come out though the top in which case you have to split the tractor between the transmission and the rear center housing. If I can be of further help email me
