multipower MF35 doesn't work
fuzzman
04-26-2005 17:56:29
The multipower does not work on my Massey. What are some things I could check?
Big Dean
04-26-2005 21:53:21
 Re: multipower MF35 doesn't work in reply to fuzzman, 04-26-2005 17:56:29
About the only thing you can check without splitting is the adjustment of the shift linkage. There are a few thing that can cause it not to work one being the shift linkage out of adjustment the multipower pump bad a broke or loose line in the transmission or rear center housing the clutch pack disc worn out the clutch pack seals being bad.
