MF 35 PTO problem
Georgia Boy
04-24-2000 15:33:50
Hope this isn't a duplicate - I tried to post it earlier and it didn't seem to make it.
I've got a 1965 MF 35, 3-cylinder Perkins diesel, pulling a 5 foot International bushhog.
The PTO will shift into ground speed proportional mode with no problem, but when I try to shift into engine speed proportional mode, it just grinds and won't go.
Any general ideas on what the problem might be? Should a novice like me let an experienced tractor repairman take care of this, or should I take a shot at it myself?
Thanks to all for your advice!
Jack in NB
04-25-2000 03:37:29
 Re: MF 35 PTO problem in reply to Georgia Boy, 04-24-2000 15:33:50
Good morning.
There are two clutch adjustments which can be completed without splitting the tractor - free play, and main pressure plate clearance. Sounds like yours is the second one, but check the free play first.
Free play is set to 1/2" or so of pedal free play by loosening the bolt clamping the pedal (or actuating bracket on some units) to the clutch operating shaft going into the transmission. The shaft (or bracket) is rotated to the correct position with a rod or screwdriver while holding the pedal, and the bolt snugged up.
If the free play is now correct, tighten the bolt - HARD. Otherwise, sooner or later the pedal slips on the shaft.
With this free play setting the PTO should stop with the pedal about an inch above the footboard.
If it's still turning with the pedal clear down, the second adjustment is through the inspection hole under the flywheel housing. Three cap screws with lock nuts, between the springs around the perimeter of the clutch.
The clearance between the heads and the rear plate determine when the PTO clutch releases. As you press the pedal down, the clearance reduces, and when they contact (usually about half way down) you feel the extra pressure on the pedal.
Factory says .080 to .090". We've found that usually is too much - PTO grinds when you try to shift it into gear and it keeps turning with the pedal all the way down. We set ours to .060 or so.
You need a GOOD 1/2" wrench, because these are usually set quite firmly and if you strip them you can't do anything more unless you split the tractor.
Hope this helps.
Marvin
04-24-2000 17:42:08
Are you sure that you are depressing the clutch pedal all the way? This model likely has a two stage clutch. One releases the differential the other the PTO. Its also possible that the clutch may be out of adjustment.
