MF 135 Perkins Gas, oil leak at rpm cable weep hol
JWyatt, NC
04-25-2005 17:36:21
Hello guys,
I posted sometime earlier about oil leaking from rpm cable housing weep hole. I replaced oil seal inside of housing and replaced housing gasket and it seem to work after I drove it around a little. However after working it a short time it's still spittin oil from the weep hole. Any ideas is appreciated as always. Thanks.
DavidP, South Wales
04-26-2005 14:25:30
 Re: MF 135 Perkins Gas, oil leak at rpm cable weep in reply to JWyatt, NC, 04-25-2005 17:36:21
Hi,
First of all are you sure the seal is fitted the right way around and square? The garter spring should be facing the engine.
Could also be excessive crank case pressure. Remove oil filler cap and check for any pressure.
If pressure is found remove the pipe at the front of the engine and make sure it's clean.
Cheers
David P
JWyatt, NC
04-27-2005 03:30:30
 Re: MF 135 Perkins Gas, oil leak at rpm cable weep in reply to DavidP, South Wales, 04-26-2005 14:25:30
The spring is facing the engine. Also I made sure the pipe was clean when I adj the valves and did some other maintenance over the winter. I have not pulled the oil cap to check for any pressure but will tomorrow. Thanks for your help.
