2135 Power Steering
Rocky Carr
04-21-2005 04:25:46
Will the power steering pump overhaul kit I see for sale for about $68.00 repair a weak pump or does the pump usally have wear in the body making pump replacement necassary? I cannot find a list of parts that the overhaul kits contain. I am working on a Massey Ferguson 2135 tractor and I just replaced both assist cylinders but the steering still seems weak, no assist at complete stop but ok if tractor is moving and at full throttle. Thanks,
Rocky
Big Dean
04-21-2005 12:41:38
 Re: 2135 Power Steering in reply to Rocky Carr, 04-21-2005 04:25:46
Hi Rocky I have found that most of the time the pump body is wore worse than the gears and the kits usually did not help at all or only for a short time now and then I have found one that I could rebuild and it would last. That has been my experience with them.
GaryF
04-21-2005 17:46:39
 Re: 2135 Power Steering in reply to Big Dean, 04-21-2005 12:41:38
Rocky..Have you checked the pressure from the pump. I had a MF204 and replaced the pump. It turns out the control valve on the steering column was worn out. There is also a relief valve inside the reservoir may it could be tweaked Pressure is supposed to be 1100 to 1200 lbs
