Gears for left and right seem fine. But
mtnbikerman
04-20-2005 04:51:32
I can"t seem to get the steering arm off the left side. I tried banging with 2 hammers. I guess I could pick up a puller. There was alot of water in the box when I opened the covers. Where should I look next. On my 35 you can get the right side off to check the gear but on the left side one bolt is blocked by the battery tray. So I took off the tank, tray and all the wires. No that hard figured I"ll learn something. Now I guess I need to pull the wheel
mtnbikerman
04-25-2005 05:18:30
 For anyone still following I only had one bearing in reply to mtnbikerman, 04-20-2005 04:51:32
steering shaft and it was toasted and the bottom bearing at the bottom of the shaft was toast also. No grease left at all. Gears are good but it was a good thing I took it apart cause the gear box was nothing but water and a little bit of oil.
