To 20 Trans lube is leaking into starter
RODNEY PERRY
04-17-2005 19:24:45
I have a To 2o Massey ferguson that gear lube is leaking into starter any ideals
Ray,IN
04-19-2005 20:43:15
 Re: To 20 Trans lube is leaking into starter in reply to RODNEY PERRY, 04-17-2005 19:24:45
Crawl underneath and find the cotter pin in the bottom of the bell housing. This must be free to jiggle around and keep that small hole open. This hole allows oil to drain and prevent your problem of oil getting on the starter nose and on the clutch disc. Some shady sellers plug this hole to eliminate oil drips while dealing. Those drips will not cause transmission failure because once the oil level is below the input shaft seal they stop. Do not use any of the seal conditioners for AT's though, the brass and bronze bushings do not like some chemicals.
marlowe
04-17-2005 20:20:31
trans input shaft seal is shot
marlowe
04-17-2005 20:22:43
 Re: To 20 Trans lube is leaking into starter in reply to marlowe, 04-17-2005 20:20:31
just one more little thing your tractor is not a massey ferguson it's just a ferguson
