TO35 intake ports
Dean Pecota
04-17-2005 15:07:14
Hi,
I have a 1957 to35. I took off the exhaust/intake manifold to replace it today and noticed the intake ports of the head were restricted by some gummed up stuff (size of restriction ~75% for one and ~60% on another). It looks like a combo of dirt/oil. The air cleaner looks like some type of oil wash system. The spark plugs look ok. I wonder if the engine is not producing as much horse power as it could due to the restriction. I cannot get the stuff out unless I remove the head. If I try to clean it out on the machine some gunk will most likely fall down on the valve beyond reach. I did not put it back together since intuitively it seems wrong to have the gunk there.
The head does not look too hard to remove. I would most likely send it out to be properly cleaned by a repair shop where the carbon build up is removed also.
Any suggestions or experiences like this?
Dean
Gerald J.
04-17-2005 17:59:54
 Re: TO35 intake ports in reply to Dean Pecota, 04-17-2005 15:07:14
Use a hooked scraper (miniature garden hoe) to pull stuff out of the passages while pulling a vacuum with a sturdy shop vac.
Gerald J.
dean Pecota
04-26-2005 09:28:13
 Re: TO35 intake ports in reply to Gerald J., 04-17-2005 17:59:54
Thanks,
I used a shop vac with a small hose duct taped to the normal oriface. It worked well. I put it back together and it started right up. I took my time and went slow. If a few pieces did get by I guess I might of taken a few hours off the life of the engine. I did not like the idea of removing the head.
Thanks Again,
Dean
1981thomasb
04-24-2005 19:30:51
question to you. Ihave a freind with a1959TO35 he dosn"tnow what the TO stands for and neither do I could you tell us. thanks
