Stuck in reverse.
Michael Oakes
04-16-2005 22:53:49
Hi,
My MF35 with Standard 23C diesel is stuck in reverse. No coaxing or cajoling will get it out. The gear stick has always been loose but never had a problem like this before.
Any ideas?
Kind Regards
Michael Oakes
Cosmo
04-17-2005 11:54:13
 Re: Stuck in reverse. in reply to Michael Oakes, 04-16-2005 22:53:49
Upon re-reading my answer I think I have the position of the large gear bass ackwards. So solly!
Cosmo
04-17-2005 06:56:45
Very common problem. Remove the hyd. filler plug to the left of the gear lever. Look for a large gear towards the front if stuck in reverse. Use a large screwdriver or similar to slide the gear to the rear. Have the hi/lo in neutral. With all pressure off the drive train it should pop back in place easily. Big Dean can explain this a lot better if this doesn't work. Good luck. Cosmo
