MH50- Any luck with electronic conversion?
zachgry
04-15-2005 10:28:23
Has anyone tried the electronic conversion kit for the mh and mf tractors. Is it worth the money and is there a down fall to these. Does it increase power and if so could you really tell a differance before and after it is installed. Also has anyone rebuilt the oil pump on those models or is it better just to buy a new one. Any info will be greatly appreciated. Thx>
txgrn
04-15-2005 17:35:11
 Re: MH50- Any luck with electronic conversion? in reply to zachgry, 04-15-2005 10:28:23
Did several electronic conversions. Would go back to points for nothing; never; bah humbug.
Mark
zachgry
04-15-2005 17:26:40
Thanks guys I will get me one.
TO35
04-15-2005 13:25:07
Hi, I use the pertronix systems and yes to your question, they are very reliable and you will notice a differance in starting and overall performance.I have installed over 60 of these over the years and every customer has been well satisified and installation is easy to accomplish.
If your oil pump shows no abnormal wear yes it is rebuildable use the factory clearance specs. and you will be alright..
Have a nice day....
TO35
Jerry/MT
04-15-2005 13:21:27
I had my distributor rebuilt (imagine that; it wore out after just 50 years of use!) and added a Pertronix ignition kit. The tractor starts in a quarter turn of the crankshaft and idles much smoother. Electronic ignition will not add power; it just provides the spark without the use of mechanical breaker points which have some reliability/maintenance problems. The spark energy can be increased by adding a hotter coil but it isn't necessary
