New clutch won't disengage
MF-88
04-14-2005 20:32:51
Regarding my MF88, I installed a new clutch, pressure plate, throw out bearing and pilot bearing and figured all will be great once complete. After bolting up the two tractor halves I found that when I depress the clutch pedal my throw out bearing is still a good half inch from the forks on the pressure plate. Adjusting the clutch free play is not enough to close the gap. At best I can get the gap down to 3/8".
Any suggestions? Could I have a incorrectly remanufactured pressure plate? I'm stumped.
Martin Y.
04-14-2005 20:42:36
 Re: New clutch won't disengage in reply to MF-88, 04-14-2005 20:32:51
First of all,Where did you find new parts for a 88? I`ve got an 85 and the 85 and 88 are very difficult to even find used parts for.You very well may not have the correct part.
Martin
MF-88
04-17-2005 20:50:52
 Re: New clutch won't disengage in reply to Martin Y., 04-14-2005 20:42:36
I use the Massey-Ferguson dealer in Lawrence, KS for my parts. If they don't have it then they call someone who, so far, has managed to come through.
As it turns out, I needed to adjust the "fingers" on my pressure plate and all is well.
