292 Chevy Engine in Massey 410 Combine
Patrick Bryant
04-13-2005 10:37:08
Anything special or different about the 292 Chevy engine in 410 Massey combine. Looks like it may be a LP fuel set up???? What problems would a person run into if he wanted to put the engine in a mid sixties Chevy pick up? Would the engine have the normal fly wheel, pressure plate and clutch set up or would it be different? I'm sure the LP could be changed over to a carb. set up. Thanks
STUDIEdiesel63
04-15-2005 01:04:31
 Re: 292 Chevy Engine in Massey 410 Combine in reply to Patrick Bryant, 04-13-2005 10:37:08
engine has normal flywheel,but you need clutch,pressure plate,and bell housing from truck.
also check pilot bushing in end of crank,as size may be different for a truck transmission input shaft.good luck!
mitchbob
04-13-2005 17:42:17
don`t know about the 410 but the 510 with the 327 and perkins d., both had only an output shaft, no clutch assembly. The clutch was on the cross shaft
