Massey 44 Standard Vs. John Deere A
Jim Calhoun
04-12-2005 19:54:14
I have a chance to buy a 1947 John Deere A with loader for $1,200.00.
The outfit is clean and in good running condition but is narrow front.
I also have a chance to save a few bucks and buy an early 1950's Massey 44 Standard (Wide front)for $800.00
The loaders are identical, the A is in a little better shape but I would prefer a wide front.
I guess what I am after is some advice from anyone who has used these models with a loader.
Which one would you buy? I realize that neither tractor is ideal for a loader without power steering or live power.
I know this is the Massey board, but I should get good unbiased advise here.
Texas Denny
04-13-2005 20:50:07
 Re: Massey 44 Standard Vs. John Deere A in reply to Jim Calhoun, 04-12-2005 19:54:14
I have a MH 44 Special with a wide front and a loader. It steers really hard. I had an A with no loader and it steered easy. Steering would probably make my decision. However, the Harris Guy is absolutely right. That hand clutch is going to be a real problem trying to run a loader. For a lot of other things it is OK. I sold my A and kept the 44 Special. If the price was higher for the Massey and it would be in a bit worse condition, I'd still rather have the Massey! I'm not real keen on standard but I'd still pick Massey. Incidentally, I have not regretted selling my A for even a fraction of a second and it was in good shape, too.
Delbert Carman
04-13-2005 11:31:38
I have ran a John Deere A with a front end loader. It is quite an experince. You have a hand clutch, hand throttle, one or two hand shift levers, depending on the year, hand hydrulic controls, and of course a hand steering wheel. Most of us don't come equipped wilth that many hands. Just thought you should consider this.
Harris Guy
04-13-2005 09:37:03
Check the steering on the 44 Standard. If the steering wheel is being turned, does the steering box "shift" at all, from the 3/8" bolts being loose/broken? How much 'play' in the steer shaft? Shoe brakes function? Central hydraulics would
help, but not all standards came with them. The
A is.... somewhat crude on features, when you
operate a decent condition 44. Loaders wear out all front ends, so check both for loose parts, welds, hack repair. Good luck.
