spring location??
in sticks
04-12-2005 13:55:05
just removed pto lever on a 135 with the two differnt pto choices to look at filter and check things out in that area.screen and the two cups were laying in bottom of trans casing.now for the question,after draining oil i find a small 1 inch long spring with the two ends on and about 3/8? inch od laying in the bottom of trans.where or what is this for???? any and all ideas appreciated
Big Dean
04-12-2005 16:54:30
 Re: spring location?? in reply to in sticks, 04-12-2005 13:55:05
That the filter came unscrewed because at sometime someone did not replace the tie wire to prevent it from coming unscrewed. The spring you found is off of a piece of the Position control linkage near the top of the liftcover. If I can be of further help Email me
