Hello Big Dean
txgrn
04-12-2005 07:01:58
Had my left foot on lots of clutch pedals.
Recently purchased a MF 35, live PTO and the leg pressure required to work the clutch is much more than any clutch I can recall. Everything works as designed including where both clutches engagae and release.
Kinda feels like somebody put in 2x the strength springs on the pp that thay should have.
Got any Ideas?
Thanks,
Mark
Massey V8 Nut.
04-16-2005 08:44:21
 Re: Hello Big Dean in reply to txgrn, 04-12-2005 07:01:58
Hi Dean,
Kirk C from Alton Kansas,
My 1155 is a sweet machine,
But to shift gear,s I have to lean forward to pull the lever,s down, ("short lever,s")
Did Massey do this intentionally,?
Or did they just wanna have a gated pattern that would work simple?
Kirk C,
jrsn
04-12-2005 17:43:10
Mark , Go to search and put in clutch plate. And massey forum. Read number 94. It explains the extra springs in some clutches like big Dean says. BARECO has pictures and tables of the springs required for different models. Ray-s
jrsn
04-12-2005 18:13:24
 Re: Hello Big Dean in reply to jrsn, 04-12-2005 17:43:10
Should of put the date in of threads. --03/31/04.-- ray
txgrn
04-13-2005 23:19:14
 Re: Hello Big Dean in reply to jrsn, 04-12-2005 18:13:24
Thanks, I'm not going to go into it; just curious.....well, not as long as my left knee holds out.
Mark
Big Dean
04-12-2005 16:45:25
Mark the two stage pressure plate assembly for tractors up through the MF1085 will bolt right in place on the MF35 the bigger tractors had stronger spring in them it is not uncommon to get a MF35 that has had one of those pressure plate assemblies install in them I have run across that several times I suspect that is what you have
txgrn
04-13-2005 23:16:48
 Re: Hello Big Dean in reply to Big Dean, 04-12-2005 16:45:25
Must be as it is a real bear to push down.
Sorry for the delay in answering. Been putting in the hay crop.
thanks,
Mark
