cant attach the hoe
hogg
04-12-2005 02:25:03
I've got mf 20 ind. tractor & a backhoe that's not attached. I got 4 brackets/braces to attach it with but can't figure the configuration out where they go. The guy I bought it off of never had the hoe attached as long as he owned it. Any pictures or directions on how to attach it would be greatly appreciated,hyd. lines & braces. or phone#,website,or e-mail of someone who could help or point me in the right direction. THANKS
GaryF
04-12-2005 17:45:47
 Re: cant attach the hoe in reply to hogg, 04-12-2005 02:25:03
Do you know which model of loader and hoe you have? Has this hoe already been on the tractor previously? Usually there are brackets that go under the loader frame and another smaller set that attach diagonally from the top of the hoe frame to the tabs on the loader frame close to your feet. This will mostly depend on the loader and hoe models.
So far as hydraulics it will depend on the loader control valve that you have there should be some type of power beyond port. How this is hooked in is critical as it is possible to deadend your hydraulic pump and since there is no relief valve in the pump (it's in the loader valve)it will break.
