1953 M-H 44 Special
Ken Young
04-11-2005 17:50:43
Just had the carb totally rebuilt. Now the only
way the engine will run properly is with the
choke fully on. Does anyone have any ideas as
to what the problem might be. Thanks for any replies
old
04-11-2005 21:02:50
 Re: 1953 M-H 44 Special in reply to Ken Young, 04-11-2005 17:50:43
Sounds like a bad rebuild, if you had some one do it for you it should have been set at factory settings and if so the tractor should run and all you would need to do is fine tune it. If you took it to a shop I'd take it back and say fix it!!
Andy Dubourt
04-11-2005 20:53:03
I wonder if something isnt stuck inside the carb, or someone forgot to adjust the fuel screws. Maybe one screw is all the way in or out? Does it stall when you open the choke? Or does it run away.
