MF TO35
ted mcrae
04-11-2005 14:17:46
RECENTLY BOUGHT A MF TO 35 WHAT IS THE CORRECT TRANS OIL/ HYD FLUID TO USE IN THIS TRACTOR?
phil(va)
04-12-2005 05:44:18
 Re: MF TO35 in reply to ted mcrae, 04-11-2005 14:17:46
Mineral Oil, or as we know it, GL-1. Not the GL-3 -- GL-5 that is sold in auto stores as gear lube. You can get GL-1 at many tractor supply stores, sometimes at Walmart, and at most of the NAPA stores, especially the rural ones. Cheaper in 5 gal buckets. The auto gear lube has additives not good for bearings in the pump. It's hard to get fully drained. Take your time and open all the drain holes, overnight is best. Uses 32 quarts if drained completely.
