MF 150 oil loss
Michael W.
04-10-2005 18:58:17
3 cyl. gas engine has steady stream of oil coming out of tachometer cable housing at back of engine. The housing has a hole in it obviously designed for oil to come out. What would be the reason the for the leak. Is something else clogged and this is a pressure relief point. Thanks in advance
Big Dean
04-10-2005 20:30:25
 Re: MF 150 oil loss in reply to Michael W., 04-10-2005 18:58:17
There is a seal in the plate that is bolted to the engine for the tach cable to connect to the oil is leaking past that seal. The weep hold is there to let the oil out so it does not get up in the tach. If I can be of further help Email me
Michael W.
04-11-2005 17:57:51
 Re: MF 150 oil loss in reply to Big Dean, 04-10-2005 20:30:25
Thanks Big Dean, I can now see where the seal will go, hope I can find one locally. Thanks again
