Zenith Carb for a MF 135
Frank W
04-10-2005 18:08:16
Need help with Carb.
1. what is the thing that is on the bottom front of the Carb. Bowl at a 45Deg angle that is round that is about 2" long that has a Needle point that is in side of the bowl. Does needle freely move or is surpose to be spring loaded.
2. Float is sticking cause carb to over fill.
thank You
Big Dean
04-10-2005 18:49:22
 Re: Zenith Carb for a MF 135 in reply to Frank W, 04-10-2005 18:08:16
That is actually a solenoid and there should be a wire from the ignition switch to it. It is spring loaded when you turn on the ignition switch it pulls the needle in away from the main jet. When you turn ignition switch off the spring pushes the needle up into the main jet to shut off the fuel to keep the engine from dieseling when you shut it off.
Frank W
04-10-2005 20:23:27
 Re: Zenith Carb for a MF 135 in reply to Big Dean, 04-10-2005 18:49:22
Big Dean:
No problem with it cutting off before I ran out of gas the other day. It would start and cut off Flushed out the carb through the bottom plug and where the solenoid is with Carb Choke cleaner.
Now the carb is fooding out.
Carb Rebuild Next??
Later
Frank W {:-{)
