Super 101???
Gust P
04-10-2005 11:35:10
Okay here"s what I got Ser # 263398 Super 101 on the radiator housing What engine is in it?? the plate on the block is really bad can make ou MFA(or 4)22 G might be other letters or # but can"t make it out. The water pump casting # is F400K-419 this is the part I need replaced or rebuilt. Also does the hub that the fan is bolted to come off or is it part of the assembly. Thanks
Bruce C
04-10-2005 17:53:25
 Re: Super 101??? in reply to Gust P, 04-10-2005 11:35:10
The 101 and 102 senior's used six cylinder continental built engines.The models 101 and super 101 used Chrysler industrial engines.On the Chrysler engines the distributor is on the LH side of the engine.On the continentail engines the distributor is on the top.The tractor is a 1945 101 senior row-crop model from the serial number you posted.
Gust P
04-10-2005 18:18:49
 Re: Super 101??? in reply to Bruce C, 04-10-2005 17:53:25
Got that finally figured out! All I need now is the model # of the engine and a part # for the water pump. Is the engine a F600? anyplace to look for a water pump replacment or fix? anyone?anyone? THANKS for all the info it's really appreciated.
Alberta Mike
04-10-2005 16:54:28
The F400 series of engines were 4-cylinder Continentals so you don't have a Super unless somebody dropped in a transplant. You might have a 101/102 Junior if the front frame is cast iron. If it is channel iron, then you have an 81/82/20/22 model (assuming it is original).
gustp
04-10-2005 17:40:25
 Re: Super 101??? in reply to Alberta Mike, 04-10-2005 16:54:28
The f400 # is on the casting 0f the water pump.The engine block # is F600A629 distributor on top. small metal plate with unreadable numbers on the left side above the dipstick.
gustp
04-10-2005 15:55:05
So what model engine number does it have? There is a casting # on the right front corner of the block F600A629. As I get more grease and crap blown off this pig I'm finding more #'s
old
04-10-2005 13:16:31
If its a super 101 it will have a 6 cylinder cysler engine in it. The dist. wil be on the side of the engine. If the dist. come out the top of the engine its probably a SR 101. I have one that says super but its not a super but a SR.
AllanC
04-10-2005 13:49:05
 Re: Super 101??? in reply to old, 04-10-2005 13:16:31
From the ser# you gave it should be a 1945 Senior row-crop. which would have the Chrysler Industrial engine.
gustp
04-10-2005 16:07:19
 Re: Super 101??? in reply to AllanC, 04-10-2005 13:49:05
The dist is on the top---so this is the chrysler set-up? What model engine is this? Anyone have the part # for the water pump.
Tom Dold
04-14-2005 16:23:49
 Re: Super 101??? in reply to gustp, 04-10-2005 16:07:19
Gustp
It appears that you have a 1945 "101" Senior with a continental engine. I have a new water pump to fit your engine if that is truly what you have. There are a couple of different water pumps, one has a steel pulley that attaches with the fan to the hub the other has a cast iron pulley pressed directly to the pump shaft. Some 226 continentals in other applications use a removable pump core similar to the 4 cylinder continentals.
Tom Dold Implement Howard, SD 605-772-4541
t
