MF 35 3 point
garvas
04-10-2005 02:35:51
Plowing the other day and when I lifted the plow it would not come down. I had to shut the tractor down to get the 3 point back down. Now it will lift and will go down if I don't move the lift lever to the very top. If I do that the 3 point goes all the way up and will not go down. I have seen this on the site here but for the life of me I can't find it in the archives.
Big Dean
04-10-2005 11:34:56
 Re: MF 35 3 point in reply to garvas, 04-10-2005 02:35:51
I sent you this in an Email but just in case it might help someone else I will also post it hear I suspect that the pump control valve return spring is the original spring that came in the pump over the years it has gotten weak and will not hold the valve oscillator drive in the valve and if the oscillator cannot rock the control valve the control valve will get a hydraulic lock and the control linkage cannot move the control valve to lower the lift.
