MF 65 power steering problem
Phil Nauert
04-23-2000 12:02:04
I have a 1960 MF 65 and as far as a I know they all came with power steering standard. On mine the power works great in a right turn but I have no power assist to the left. This makes for some interesting mowing as I avoid left turns whenever possible. Any suggestions to fix the problem?
CAM
04-27-2000 06:12:41
 Re: MF 65 power steering problem in reply to Phil Nauert, 04-23-2000 12:02:04
My MF 65 had the same problem. Try the turn buckle adjustments on the front steering pedestal. Usually this takes care of left and right turning. Mine wouldn't turn in one direction because one of the front wheel spindles was partially frozen in its support. Check to see if the grease fittings are taking grease first. I took the front tie rod ends off and found that one wheel could not be turned by hand while it was off the ground. After I got the spindle free and greased eveything worked fine. Try moving round bales out of the field without being able to turn both directions. Good Luck,
CAM
Jack in NB
04-24-2000 03:59:41
Phil -
There's a turnbuckle behind the grill, connecting a bracket on the main vertical shaft to the control valve on the top of the power steering cylinder. That's where the action is.
If you watch the valve while your trusty assistant rocks the steering wheel from side to side, you'll see the valve spool move - probably only one way, and back to center. Very slight movement - 1/16" or less. That movement is all it takes to energize the power steering.
You will also see slop in the pins connecting the linkage, possibly the turnbuckle itself is flopping.
Because of the very little movement needed, the slop may not allow enough travel to operate both ways.
Try adjusting the turnbuckle first to get travel both ways on the control valve spool. If the spool is pulling out and not pushing in, lengthen the turnbuckle, or vice versa.
A caution: be careful not to shorten the turnbuckle too much. If you pull the control valve spool too far out, you can bugger the retaining snap ring inside the valve, and the valve will leak. And that's a really tricky problem to fix.
Loosen the lock nut(s) and rotate the turnbuckle 1/4 turn at a time, turn the wheel back and forth, check the spool to see if you're turning the turnbuckle in the right direction to get spool travel where you did not have it before.
If that doesn't give you enough assist, the next step is to replace the pins. They are almost always worn. (Who would ever think to oil them when servicing?) Readjust the turnbuckle.
If that doesn't remove enough slop the next step is to redrill the holes in the spool, turnbuckle rod/end, and casting and replace with next larger size. We had to reenforce a couple of the holes with brazing.
Hope this helps.
