oil pressure reading
ex jd man
04-09-2005 18:42:47
I bought a 52 model 44,been disking with it.my question is whats the oil pressure run after its warmed up,mine runs a little over 20 cold but after it warms up good it drops to 10-12 pulling it,is this ok and 5-7 idleing.thanks
Bruce C
04-09-2005 21:09:21
 Re: oil pressure reading in reply to ex jd man, 04-09-2005 18:42:47
My manual says the oil pressure at a idle is 5 psi.15 to 20 psi at governed speed.This is with the engine at operateing temp.You could have worn main or rod bearings,worn pump gears.I would be looking for the cause of the drop in pressure.
txblu
04-10-2005 07:27:42
 Re: oil pressure reading in reply to Bruce C, 04-09-2005 21:09:21
Higher viscosity oil gives higher oil pressure readings..... everything else equal. If you are using light oil and don't like your pressure (which is too low for me) up your viscosity.
Mark
