mh 50 , will not fire
lloyd
04-08-2005 10:11:22
? unable to fire,all new>>>coil,points,batt,plugs & wire,cap,rotor,brecker plate new,,,,will not fire,,,help,red.
Dave_Id
04-08-2005 10:55:03
 Re: mh 50 , will not fire in reply to lloyd, 04-08-2005 10:11:22
It takes 3 things for your engine to run. Fuel, Compression, and spark. So if you have compression and fuel,(good working carb) then look at your spark, It comes down to timing. Check number one compression at spark plug,make sure rotor is pointed to number one plug wire on distributer. Check rotation, of distributer and make sure wires are on correctly. Check point gap... I'm sure others willl have more suggestions.
