Broken front drive shaft
Rich K
04-07-2005 04:41:02
We are working on an MF3660 and found the front drive shaft snapped off next to the front support. Does anyone have a parts breakdown showing this and part numbers? Owner wants to know how much $$ before we begin repair. Thanks.
MHF
04-08-2005 13:14:13
 Re: Broken front drive shaft in reply to Rich K, 04-07-2005 04:41:02
The drive shaft or the stub coming out of FWA. The drive shaft is aroud $600, couplers around $100 a peice. You can get over a $1000 in part on the inside you have to buy a new ring gear and pinion if the stub is broke. Not to bad to fix. You can have a little trouble getting the what i call ball joint bearings out, but after that the axles just slide out and so on and so. There is a number on the pinion that you"ll have to plug into an equasion if I remeber right it was in French but if I can figure it out YOU"LL HAVE NO PROBLEM. Let me know if you need help.
Rich K
04-08-2005 15:50:21
 Re: Broken front drive shaft in reply to MHF, 04-08-2005 13:14:13
Thanks, MHF, It was the front stub shaft that broke off. Please email me - [email protected]
marlowe
04-07-2005 16:29:22
when i worked for massey we went to a drive shaft shop that makes them for trucks and they allways were a lot cheeper. we had two in greenbay wi. that did them for us
