Picked up a MH today no clue as what it is
old
04-06-2005 19:22:42
This tractor looks a lot like my 101SR. but it has a 4 cylinder flat head engine, 38 inch tires and other then the engine looks so close to the 101SR it almost could be a 101SR. Is it maybe a 101JR?? Also where do you find the serail numbers on it?? Did find a few numbers that look like a date but not sure the last two in them was 47 so I'm thinking its a 1947 tractor. Thanks for your help.
Bruce C
04-06-2005 21:34:08
 Re: Picked up a MH today no clue as what it is in reply to old, 04-06-2005 19:22:42
The 101 and 102 seniors used a six cylinder engine.The 101 and 102 juniors used a four cylinder engine.Both engines were a flat head built by continental engines.The serial number is stamped into the top of the rear-end houseing on the left-hand side just behind the pto shifter houseing.You may have to do some cleaning to see the number.There also should be a casting number on the front u-frame it could be on the under-side or on either side below the gas tank.It will give you the day,month and year it was made.This is also a way to date the year of the tractor.Post the complete numbers and someone will be able to give you the proper year and model.There is also a model number on the engine on a machined surface just below the head it can be on either side.
