three point wont stay up
rylos
04-03-2005 19:19:15
Ok I am doing a bunch of work to my mf-35. Just did axel seals and now I want to fix my three-point lift while I have it apart for the multi-power fix.
So my question is this.. The three point leaks down after I turn the engine off. I know it will do this but it only takes about one minute to do so. So what is my fix? Should i even worry about it?
Big Dean
04-03-2005 23:59:23
 Re: three point wont stay up in reply to rylos, 04-03-2005 19:19:15
Drain the oil down to just below the bottom bolt of the access plates on the side of the rear center housing. Remove the right side access plate star the tractor and lift something with the lift. Look through the access hold for oil running down from the top side that would be a lift cylinder problem or a bad O-ring. Check the O-rings on the standpipe. Look for heavy turbulence near the right rear corner of the pump that would be caused by a bad relief valve. If it is none of those it is probably the Control valve in the pump. That is what I found causing that problem most of the time on those old tractors. If I can be of further help Email me.
rylos
04-04-2005 06:25:42
 Re: three point wont stay up in reply to Big Dean, 04-03-2005 23:59:23
as always... thanks for the help big dean.
