Massey 1100, 1105, 1130, 1135
wny mark
04-03-2005 13:02:36
I was wondering about a comparison of these 4 tractors. I have a lot of experince with the 1100 but what are the differences with these others. Looking to go pulling against some stout IH 10-1466 as well as JD 4430 What tractor should i go for that can be reduced on weight. Want one with factory turbo if possible. What is the potential for the 354? Can i get it to run 400 horse? Seems like the IH an JD guys are getting this many HP. Anyone with experience or tips would be appresiated.
Holm
04-07-2005 14:16:42
 Re: Massey 1100, 1105, 1130, 1135 in reply to wny mark, 04-03-2005 13:02:36
They all have the same engine but the 1105 1130 1135 are turboed.To beat a 1066 1466 4430 I would suggest going to a 1150 1155 adding the correct turbo,having the injection pump rebuilt for pulling and going to big injectors.I pulled a 1150 for years that I also farmed with.You can get that tractor down to 8500lbs if you take everything off that you don't need. I could run road gear at 8500 lbs.You would have to spend a lot more money trying to get the hp out of a 354 perkins.
