Help! TO35 Hung up in first gear
Gene
06-14-1999 15:04:44
I bought a TO35 Special gas burner Serial No. 199194 in good shape about 2 wks ago. Last weekend I was bush hogging in light grass when I stopped to backup and the gear shift was hung up in low range first gear. High/low shift still works. This is the first Ferguson that I have owned. Is this a problem with this model tractor? Is there a way to get the tractor out of gear back to neutral without going into the transmission? I don't have any manuals yet,but it looks like you can go into the top of the transmission fairly easy.
Any help an/or suggestions would be appreciated.
Gene Ledbetter
Sneedville, Tennessee
Martin
04-23-2000 12:45:28
 Knocking noise with PTO. MF35 in reply to
Ray Hubbard
06-15-1999 10:14:00
 Re: Help! TO35 Hung up in first gear in reply to Gene, 06-14-1999 15:04:44
Gene:
Does your shifter lever seem to be in neutral but with a lot less left to right travel? If so your fork is probably moved ahead without the lever. You need to bring the fork back to center so the lever can re-engage it.
I have an F40 which hung in first gear. I was on a steep hill backing up. I shut off the engine to unload and when I got back on the tractor I clutched it and shifted to second before starting the engine. Evidenty, the shifting fork continued to travel due to gravity and speed when coming out of reverse. It went directly to low without the lever following.
I opened the oil fill plug and with a long screwdriver and flashlight saw the fork not centered. Easily popped it back to centerposition and back in business.
If you lever is also stuck in the low position then I can't help.
Ray
sawdustoldiron
04-22-2000 19:35:48
 Old Iron Links - Calendar of Events in reply to Gene, 06-14-1999 15:04:44
vince
04-22-2000 18:04:21
 MF 1225 HYDRO PROBLEM in reply to Gene, 06-14-1999 15:04:44
Georgia Boy
04-24-2000 15:04:49
 MF 35 best PTO option for bushhogging in reply to Gene, 06-14-1999 15:04:44
