MF 65 weight????
James S
04-01-2005 18:59:53
Hello everyone i just need to know how much my 1959 MF65 Row Crop wieghts. If anyone can tell me i would really apreciate it because i am going to buy a new utility trailer and i want it with enough capacity to move my 65 on.
Thanks ahead of time.
Billy McCarver
05-16-2005 01:21:40
 Re: MF 65 weight???? in reply to James S, 04-01-2005 18:59:53
I have a two axle (3500# each) trailer that I use to move my tractors (mf65 dieselmatic and IH240 utility) with. The trailer weighs about 1400# so the combination of tractor and trailer pushed the limits of my class 3 hitch (6000 trailer/500 tongue) a little. The receiver was rated higher. But with careful placement of the tractor on the trailer and secure chaining no problem. Just be careful to keep tight turns to a minimum and give yourself plenty of room to stop along with keeping your speed reasonable. I've used both an F150 and a F250 super duty to pull with. Just had to be sure to stay out of overdrive with the F150. One thing I'm short on is trailer brakes. Having electric trailer brakes on at least one axle would be a big plus on the safety side. Billy
phil(va)
04-02-2005 15:10:03
A standard bumper hitch type double axle trailer with brakes on at least one axle has 7,000 lbs gross weight (two 3500 lb axles). You don't want any less than that, no matter what the tractor weighs. It probably won't be the only tractor you will haul with that trailer.
Lou
04-02-2005 10:01:54
Tractor data.com has the 65 at 4083 lbs. Are your tires loaded? good luck Lou
