MF 35X Hydrolics Won't go down
Terry Fisher
04-01-2005 10:27:49
I have a MF 35X , and with the mower on the back of the 3-point, I can raise and lower it just like normal (I guess because it is so heavy). But when I put on the post hole auger, and raise the draft control , it will go up , but will not go down when lowering the draft control alone. You have to remove a plug on the top of the main transmission case cover plate right above the PTO lever to bleed of oil. Does anybody know what I need to do to fix this problem?
Thomas
04-02-2005 12:08:24
 Re: MF 35X Hydrolics Won't go down in reply to Terry Fisher, 04-01-2005 10:27:49
Why are you using the draft lever for non soil engaging implements? You should leave this lever at the top and use the position control. The problem will be due to free play in the draft control spring (top link). The heavy mower will be pulling it tight all the time, the lighter implement may allow it to float, and the internal linkage will put the pump into lift. Pull back the rubber boot, undo the grub screws and undo the special nut (angle grinder spanner will usually fit). Check the spring is not broken and is tight - if it is loose you will need to screw the assembly together. Refit the spring assembly and tighten the nut until you have taken up the slack. Mark the nut with paint, continue to tighten, counting the number of turns, until the linkage begins to feel slack again. Turn the nut back to half way between these two extremes and you should be OK. The hardest part will probably be to get the grub screws and nut loose, as they are always rusted up. A gas axe becomes essential, but keep it away from the spring.
