water pump for 101 Sr
Gust P
03-30-2005 17:58:24
Anyone know where I can get a water pump rebuilt for a twin power 101 Sr? Either core exchange, kit, or rebuild---just so it quits leaking so I can use it!!! Thanks
Kevin Bismark
04-02-2005 20:34:19
 Re: water pump for 101 Sr in reply to Gust P, 03-30-2005 17:58:24
Wouldn"tn think that would be too hard to come by, the chrysler industrial engine was a lot of them made, have you tried to go to an auto parts place with a good guy behind the counter?? would think they could hook you up with something, when you come up with something please post where you found the parts, might be nice to know... good luck..
Dave_Id
04-04-2005 12:56:19
 Re: water pump for 101 Sr in reply to Kevin Bismark, 04-02-2005 20:34:19
The 101 Sr used the Continental F226
thehickdaddy
04-05-2005 02:08:51
 MF 235 steering play in reply to Dave_Id, 04-04-2005 12:56:19
my uncle asked me the other day to look at his mf 235 the other day. he picked it up over the winter and wanted me to look at the steering before he started haying this spring with it. the powersteering seems to work exellent but when travelling down the road the front wheels shimmy while the steering wheel is held straight. the drop arms out of the steering box have about an inch or so of travel back and forth before the steering wheel moves, when you lift up the front axle so everything can move. also, when the left drop is moved back and forth by hand the steering column moves up and down out of the dash about three quarters of an inch. i did not see any adjustments for the drop arms like the old ferg 30 had. is the box mechanically shot? are parts availible. any help helps. thanks. thehickdaddy
thehickdaddy
04-05-2005 02:17:17
 Re: MF 235 steering play in reply to thehickdaddy, 04-05-2005 02:08:51
sorry, posted this in the wrong spot, silly technology
Dave_Id
03-31-2005 13:06:07
There is nothing to them except a few gaskets, take it apart, and you'll see
