Remote Hydraulics for a MF 35
cj1562
03-30-2005 16:49:29
Can someone tell if it is possible to add remote hydraulic system to a 1957 MF 35 Deluxe?? If so where would i go to find out how to do it and get the parts...
Thanks
cj
DavidP,South Wales
03-31-2005 11:51:30
 Re: Remote Hydraulics for a MF 35 in reply to cj1562, 03-30-2005 16:49:29
Hi CJ
No problem at all adding an external system. There should be plenty of different "isolating" valves available to fit on the front of the lift cover under the seat. You are of course limited to using the main hydraulic pump where as later tractors (MF) had an auxillary pump for this purpose.
You can use the cross tapping on the side of the lift cover and have a return either to the oil filler plug or just in front of the main cross shaft on the left hand side of the cover.
To use this method you will need to be able to prevent the lift arms rising fully to maintain oil supply. The "iso" valve is a far better option but take time to think about what you want to do.
Is it for a loader, or trailer, how many services do you need? The spool valves can be mounted almost anywhere but as above check for access. Don't skimp on any brackets to mount it.
Cheers
David P
txblu
03-30-2005 23:23:22
I had one with dual factory remotes, located where Gerald said.
BUTTTTT TTTTT TTT the levers were right in your way and mounting and dismounting was a real pain; especially with that deluxe seat with the back and all.
That is probably my only rub with that vintage of Fergie as compared to Ford. Just hard to get on and off and for a utility, when you can't get on and off quickly, easily, and safely, it's a bummer.
Mark
KCTractors
03-31-2005 18:56:15
 Re: Remote Hydraulics for a MF 35 in reply to txblu, 03-30-2005 23:23:22
Boy! You said it about the levers making it difficult to get on and off. I"m thinking about putting a PTO pump on with another valve just for the loader. The levers sure made a handy tractor very unhandy especially when you are short.
txblu
04-01-2005 06:23:42
 Re: Remote Hydraulics for a MF 35 in reply to KCTractors, 03-31-2005 18:56:15
I can imagine as I'm 6'5 and it was all I could do to swing my legs over to get on or off.
Mark
Gerald J.
03-30-2005 18:18:48
MF and Cross made a remote valve that mounted under the seat and taps the hydraulics in the lift cover. I don't know if its still available, but that's the neatest way to get remotes.
Gerald J.
Rod in Smiths Falls, ON,
03-31-2005 19:21:39
 Diverter valve PIX in reply to Gerald J., 03-30-2005 18:18:48
This one works pretty well unless I jog it with my foot.
Gerald J.
04-01-2005 06:26:37
 Re: Diverter valve PIX in reply to Rod in Smiths Falls, ON, , 03-31-2005 19:21:39
I see you are running 3000 psi oil through 175 psi cast street elbows. Think that's safe all the time?
Gerald J.
04-01-2005 16:25:18
 Re: Diverter valve PIX in reply to Gerald J., 04-01-2005 06:26:37
I don't think those elbows are cast. I had to hack away at another one and the steel wasn't grainy at all.
But hey, I don't know. The guy who installed it is a heavy machinery technician who took the leap into dairy farming. I'd tend to trust his judgement.
