confused on multi-power fix.. please help
rylos
03-30-2005 14:11:54
Ok I need some help. Got a mf35 with multi-power. Going to fix the leak and have called 4 or 5 shops. They have said everything from �you just need to replace the seals� to �You have to replace the housing, throw out bearing, gear cluster, and seals at the low cost of 1,000.00� �if you only replace the seals it will start to leak in a couple of days�
So what gives? Does anybody have a multi-power that they have fixed? What is the correct answer?
Kevin Bismark
04-01-2005 15:21:12
 Re: confused on multi-power fix.. please help in reply to rylos, 03-30-2005 14:11:54
Ask Big Dean about that one, he would be the one to tell you what to look for on that one..supprised he hasn't said anything here yet..
