Injection Pump
jspaulding
03-29-2005 19:46:58
I have bought a Massey Ferguson 3165 for four hundred dollers. It has a AD4-203 Perkins with a Cav injection pump that well does not pump. Can anyone help me figure out what could be wrong or where i could get an injection pump. And yes it has a new fuel lift pump on it but it still will not push fuel out of the injection pump. so if any one can help me with what is wrong with it or where i can find a new one it would be appreciated.
DavidP,South Wales
03-30-2005 10:19:50
 Re: Injection Pump in reply to jspaulding, 03-29-2005 19:46:58
Hi,
Have you bled the pump? If not you will find 2 5/16" spanner size screws on the outside of the pump, 1 in the lower body 1 in the upper.
Disconnect the supply pipe at the rear of the pump and operate the lift pump to ensure that you are getting diesel to the main pump. Reconnect the pipe and slacken screws. You should have anything between a dribble and a strong jet coming from each screw. If you have this slacken at least 2 injector pipe nuts and turn the engine over. You should see evidence of diesel at the nuts. Close the nuts and attempt to start.
Having diesel at the nuts is not an indication that the pump is OK. The pressure may be insufficient to crack the injectors. Remove the pump and have it tested. A full rebuild would be approximately �220.00, I guess that's around $350.00.
Good luck
David P
